Posts: 7 |
Whats up fello speed freaks! If you live anywhere around Dayton Ohio you should stop by itsturbo.net!!! This place is a awsome turbo kit manufacturer and installer!! I had no idea anything like this was available in Ohio, atleast not in my backyard! Long story short they are using my cat to manufacture a turbo kit for our 2.5L engines. It will be a 6psi turbo w/ a air to air intercooler for UNDER $3800!!! You will not find a better deal, give Carson a call at itsturbo 937-533-1730 and tell him Nathan Brown told you to!! You will get great quick service!
HKS filter, 75mm programmed Maf, SVT TB, SVT intake plinum, UR underdrive pulley, MSD Dig. ignition with Vitech 8.5 wires, 42lb injectors, Garret T28 turbo, air to air intercooler with nitrous installed,
Posts: 1,173 |
Sounds good...be sure to post some dyno results.
-Brian
2002 Jaguar X-Type 3.0 ATX - British Racing Green (two-tone) - 44,000+ miles
Former owner of a black '99 SE Sport Duratec ATX - 107,000+ miles
Posts: 7,025 |
Originally posted by cougarsvt: It will be a 6psi turbo w/ a air to air intercooler
where are you going to fit the air/air intercooler?
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,087 |
Originally posted by cougarsvt: Whats up fello speed freaks! If you live anywhere around Dayton Ohio you should stop by itsturbo.net!!! This place is a awsome turbo kit manufacturer and installer!! I had no idea anything like this was available in Ohio, atleast not in my backyard! Long story short they are using my cat to manufacture a turbo kit for our 2.5L engines. It will be a 6psi turbo w/ a air to air intercooler for UNDER $3800!!! You will not find a better deal, give Carson a call at itsturbo 937-533-1730 and tell him Nathan Brown told you to!! You will get great quick service!
This sounds like an advertisement...
Matt
2002 Subaru Impreza WRX (WRB Stage 4+)
Old Rides:
1999 Sil-Fro SVT Contour 3.0L with goodies (Totalled 6/21/06)
1988 Bronco II (Sold)
You know you launch hard when you beat oncoming traffic through their own crosswalk lines.
Posts: 7 |
No no, im just a guy passing on good info for the people out there that want to save money.
Posts: 270 |
Were is their new location??
-chris
Dayton, OH
99 Se,MTX,TS.
Koni,Eibach,SVT Plastic,tunes,Opt Y-Pipe, Elky mesh, DMD, SVT BRAKING, Eo's, 95 Leather int.
