#550171 02/17/03 10:10 PM
I have a gas smell under the hood and in the people compartment when the engine is cold. Suggestions as to source or corrective action?
Black E0 #460
#550172 02/17/03 11:30 PM
Check the following:
- evaporative emissions hose (short (about 3-4 inches long) elbow-shaped rubber hose) that connects to the PCV valve.
- evaporative emissions tube (long (about 2-3 feet long) plastic ribbed tube) that connects to the afore-mentioned evaporative emissions hose and runs along the back of the engine firewall. Be careful when you check this tube since it is brittle and cracks very easily.
I had a rip in my evaporative emissions hose, which led to a gaseous smell every so often.
If its not this, then it could be your catalytic converter is bad.
#550173 02/19/03 02:20 PM
Thanks very much for the help. I'll check those.
Black E0 #460
#550174 02/20/03 01:55 AM
V
V
while we are on the subjects of smells in the car, everyonce and a while when i really get on the car it sometimes get like a rotten egg smell. what could be some causes for this to happen?
#550175 02/20/03 02:05 AM
N
N
Catalytic converter going out?
2001 ATX V6 Dark Shadow Grey Merc Cougar(Sport Pkg, ABS, traction control and sunroof )
#550176 02/20/03 02:26 AM
V
V
man that would totally suck because i have to go for emmissions in a few weeks. how much does a performance cat cost?
#550177 02/20/03 03:08 AM
Hydrogen sulfide odor in your exhaust usually will go away if you fill up with gas from a different fuel supplier.
It does not necessarily mean your cats are bad.
Steve
#550178 02/20/03 03:32 AM
I got a rotten egg smell the very first and last time I used TEXACO gas.
Now I only use Citgo, Hess, Amoco, or Sunoco.
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
#550179 02/20/03 03:51 AM
2
Also caused by lean burning. Had a CE code pop up too?
#550180 02/20/03 04:04 AM
V
V
the check engine light did come on, but when i was putting in my system i disconnected the battery and it hasnt came on since.
