#547492 02/14/03 12:07 AM
i have a loud moaning that happens once in a while coming from my engine bay. it goes away every time i hit the gas a starts moaning as soon as i let off. any ideas?
Might be what is called moosing.
9
Try the throttle hang fix! It worked for me! It only cost $ 0.21 for the piece and was easy to install!
fix
My car does the same thing. It doesn't stall out though. I heard from a mechanic that a sensor of fords is known to hum like that. I don't know but its really unnerving.
My ears are always open!
