Posts: 57 |
I need to know because I am going to go buy tires soon. thanks
Posts: 1,020 |
If anywhere, they will probably rub on the fender liners in the back. Some do, some dont. It depends on the type of tire. They all are a little different. There are a lot of posts about this, try a search
Posts: 57 |
I just tried a search but didn't come up with anything useful. I do have passengers from time to time in the back and the orads around here suck so I am thinking I should go with 215 to be on the safe side. Unless someone can come forth and persuade me otherwise!
Posts: 3,076 |
Nope, they dont rub, Im running them all the way around. Soon to be replaced with 18"s and 215/45/18
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 661 |
Originally posted by CarpePoon: Nope, they dont rub, Im running them all the way around. Soon to be replaced with 18"s and 215/45/18
Those will rub! Maybe try 215/40/18..
99 SVT Contour Silver Frost, #365/2760, DMD
98 Audi A4 2.8 Quattro Tiptronic, 30V -- SOLD!
91 Isuzu Impulse XS Kammback, Handling By Lotus
Victoria, BC, Canada
Posts: 57 |
I don't want to go any smaller on the walls then 50, the ride gets worse and worse. I think I will stick with 215s just to be on the safe side, I suppose 225's with stock rims will overlap the rim a bit.
Posts: 1,173 |
Originally posted by 98TRED: I don't want to go any smaller on the walls then 50, the ride gets worse and worse. I think I will stick with 215s just to be on the safe side, I suppose 225's with stock rims will overlap the rim a bit.
E0's came stock with 205 series tires, so anything over that will definitely overlap the rim. 205's don't overlap on E1s at all though. I think most wheel/tire combos are designed to have some overlap...it looks good.
But yeah, lets see some tire models that you guys know for a fact won't rub that are 225/50/16s and are all-season...I'm gonna need a new set in the summer or fall and want to go to that series.
-Brian
2002 Jaguar X-Type 3.0 ATX - British Racing Green (two-tone) - 44,000+ miles
Former owner of a black '99 SE Sport Duratec ATX - 107,000+ miles
Posts: 1,020 |
Both E0 and E1 rims are 6.5" wide. So the same size tires will fit. 98.5 and up cars have revised fender liners due to the change from 205/55 to 215/50 tires. Because of this, the chances of 225/50 tires rubbing is less on 98.5 + cars.
Being stock ride height will make rubbing even less of a problem.
CEG road warrior
CEG road warrior
Posts: 17,248 |
I have 225/50/16 Nitto 450s on my E1s and they rub when someone is in back.  BTW I have Eibach springs/ST200 struts.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 57 |
I know a little over lapping looks good. Someone changed my tires before I had the car to 215/50, the same tires as the E1's. They look good like that so I think I will just stick with the same size but different tires.
