The kit originally had some problems with reliability but by all accounts that has been fixed so it is a good reliable power adder. A 3L swap will run you about the same cost wise overall but won't add the same amount of power, but should last longer (relatively speaking). The turbo kit is out there too producing great results, but also cost is an issue as it's higher than the S/C or basic 3L swap.
Rick
