N
N
my 2.5 went today it is a 98' with a build date of 6/97. i found a 2000 3.0 long block with next to no miles for a grand. is this a good deal. can i put the whole motor in or do i need to swap things around a little. i am not sure if my 2.5 heads are any good yet. what should i and do i need to do. any help is much appreciated. i am between a rock and hard place here so any and all help is greatly greatly appreciated. my direct email add. is never2fastF4i@aol.com
Learned patience the hard way
The 2000 is not the engine you want if you're trying to keep the whole motor and do a complete 3L swap rather than the hybrid. You want a 99 or mid 98 block. $1000 is too much for the engine unless it's all ready been fully prepped then it's a helluva bargain. If you need someone to do a prepped shortblock for you PM me and I can give you a quote.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180 Buckshot77@msn.com Misc 3L parts for sale
Redneck Troll
Redneck Troll
Actually a 2000 with next to no miles is about right for the full assembly. The 2000 will require the most work though as it doesn't have the WP in the right place, plus you'd have to run the 2.5 heads with the 2.5 intakes or adapt the cables and such to run the 3L heads with the 3L intakes since the heads are oval ports and won't adapt well to the 2.5 intakes without an adapter plate.
N
N
ok so i need a 99 short block, what kind of modifications are needed to the heads and block... where can i find a 99 short block already prepped and what will it run me? am i better doing it all myself? do i need to change computer or exhaust? i know it seems like a lot of questions, but i really want to know everything about this before i start diving in
I can sell you a prepped 99 block. PM me for pricing. The heads bolt straight on so no prep work needed on those and I have those available as well. On cam would need the waterpump drive cut off. Computer and exhaust are ok as stock to begin with but some type of tuning will gain you much better yeild than just leaving it on stock items. I also offer enhanced exhaust manifolds as well.
Rick
