Posts: 28 |
98 Contour SE, Zetec Powered, ATX
Silverstars, Ghetto caps
Posts: 4,714 |
Please turn off the caps lock!!!
I just saw a thread, but I'm not sure where, and the prices tossed around for the serp. belt were between $15-$25. You could probably do it yourself, but you have to be careful of screwing up and voiding your extended warranty. Legally they can't do any work without your approval, so if there are any charges on your bill that you didn't authorize, give them holy hell!
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 3,506 |
That looks like labor to be.....are you sure you understod them right and you didn;t mix anything...cause a belt for 80 is absurd.
Roz
Posts: 427 |
yup, what he said. They can't do any work without your consent. I would raise some hell and since they probably already threw your old belt away they will have to give you the new belt but they can't charge you for it since you didn't authorize them to do that work.
Traded in - 2000 SVT Black tan leather
DMD, Pro-Flow 75mm MAF, SHO Shop Intake
Mystery mod(awaiting installation)
Now 2004 Acura RSX Type S
2003 Honda Civic Hybrid
Posts: 28 |
Sorry for the caps, but I was a litle miffed. I talked to one of the customer service reps and she said they were still working on it. She went in back to grab the file and see what was wrong with it. That is where she told me about the problems and the serp belt. I think the price was just for labor. I am expecting a call from the manager regarding this issue. If it is still on the bill when I get there, (hopefully it will be done tonight) I will certainly let them know that I did not authorize that repair.
But does anyone know how hard it is to change the belt, is it like the fox bodied mustang, 5-min and your done or is it more complex than that.
Thanks in advance for the input.
Posts: 4,714 |
Search is your friend! I found this in under 5 minutes. clickyIf you want/need more detail, I highly suggest going to Autozone or wherever and buying a Haynes manual. If you plan on doing this kind of work on a regular basis, the Haynes manual will pay for itself many times over.
Hooray Beer.
Pictures
Posts: 667 |
Once you know how to do it, it is simple.
The price of the belt is about $20-25.
You will also need a tool to remove the tension on the belt. Some model years have very little clearance (less than 1/2") to get the tool into the belt tensioner.
Some people seem to be able to relieve the tension from above (in the engine bay), whereas some people can only do it from the below (the RF wheel well area). It all depends on your model year. If you have to relieve the tension from below, then you will need to jack up the car and remove the RF (right front) wheel and the splash guard.
Time to do this depends on your model year. It can take anywhere from 10 minutes up to an hour.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
Posts: 28 |
Hey, thanks for the how-to. Unfortunately I am at work and have a hard time with the search feature. I knew I could count on you guys.  CEG Rocks.
Posts: 1,731 |
I have to replace mine too.. hopefully I can do it from the engine bay.. havn't looked at it yet.. is the serpentine belt the belt under the platic housing in the front of the manifold?
Black 98.5 SVT
"Kellie"
First rule of italian driving: What is behind you, DOESN'T matter
Posts: 667 |
Originally posted by Kevdogg410: is the serpentine belt the belt under the platic housing in the front of the manifold?
No, that is the water pump belt. The serpentine belt is on the other side of the engine (on the passenger side).
96 Contour SE
108,000 mi.
