Does any one happen to know the part numbers for the two large hoses that connect to the weter pump housing? One goes to the block and one goes to a manifold. I am replacing the water pump and all hoses, but I can't find the part numbers for these two.
Thanks!
Cranky
Those hoses came with my water pump. If you are using an aftermarket water pump with the metal impeller it may not have the hoses included.
So they can't be ordered new from Ford?
Cranky
Webmaster
Webmaster
You might try Napa... they usually have these types of hoses.
-Lance
Lance Kinley CEG Webmaster 95 SE, "Cassandra" 10 years!
I'll try to remember to look up all the hoses NAPA lists tomorrow.
Here's what NAPA lists (these are all NBH parts):
8880, Lower Rad Hose (Rad to Pipe)
8937, Lower Rad Hose (Pipe to Thermostat)
8840, Upper Rad Hose
11105, Heater to Manifold
10031, Resevoir to Rad (Cut to Fit)
11184, Resevoir to Water Pump
11074, Heater to Connector
11064, Outlet to Thermostat
9081, Water Pump Inlet (Cut to Fit)
My store doesn't actually have ANY of these in stock, but we can get any of them for the next morning (at no additional cost). The "Cut to Fit" hoses are simply multi-purpose hoses that are cut depending on the needed length. You should be able to price these on NAPA's website. www.napaonline.com
