hey bro, this is what you do, when you take off the door panels, there should be about 6-7 screws on each door, and some are covered with a plastic cap. once you unscrew all the screws, you lift the door panel up and towards the window, because at the top of the panel, it clips on in a few places. as far as the window motor, leave it stationary, and push the actual button you roll the window down with up and over. i hope this helps you out, and it is much easier putting the door panel on then taking it off, if you have any more questions, you can e-mail me at
Foursquare0404@aol.com. i installed all new speakers in my 2000 mystique, hopefully it is the same as your 2000 contour, well, thats my 2 cents. late
Dr.Eon
