Posts: 1,460 |
I have an amp and cap that need to be grounded. my question is, can they both be grounded to the same spot or is that a bad thing? ive heard u can and ive heard u cant. i would like to hear other opinions about it. would i run into any problems grounding them to the same place??
'99 ČoňtôúŔ SE
Kenwood KDC-MPV7019
AudioBahn AW1206T Flame Q Sub
AudioBahn 1300HCQ Amp
Blue LED Switches and HVAC
Posts: 13 |
No problem at all, just make sure to (this is going to scare some guys around here) completely scrap away all paint of your grounding point untill you can actually see the metal, this will prevent engine noises.
How ever engine noises may be caused by several reasons.
I feel Guilty, Oh so guilty
Posts: 4,789 |
Originally posted by David Adan: No problem at all, just make sure to (this is going to scare some guys around here) completely scrap away all paint of your grounding point untill you can actually see the metal, this will prevent engine noises.
Not going to scare anyone here.
-Mitch Hedberg
Posts: 1,460 |
i said f it and i bought some more screws and im grounding em separetly, just to be on the safe side.
'99 ČoňtôúŔ SE
Kenwood KDC-MPV7019
Posts: 7,100 |
Ground loops are caused by multiple grounds.. If you are going to ground them seperately, then make sure to keep your grounds as short as possible, and file away to the bare metal, as stated earlier.. Here's hoping..
Ray
'99 CSVT - Silver #222/276
Posts: 1,460 |
So i shouldnt have the ground wire for my cap more then like a 1ft? i think its like a foot and a half....
'99 ČoňtôúŔ SE
Kenwood KDC-MPV7019
Posts: 7,100 |
1.5 should be fine. Make sure it is very tightly ground, and bare metal. Don't run your ground wire parallel to any power wires, or any wires with high signals.
Have fun, too..
Ray
