you need to check the code at a dealer. if the pcm is recieving an incorrect code, the pcm will need to be reprogrammed. if it is recieving no code, the key will have to be replaced, and if there is a circuit failure, the transponder will need to be replaced or the wiring repaired. PATS is not very user-friendly when it comes to fixing it yourself.
