Need some help here guys. Had to change out a timing belt guide today. I can't get the timing dialed in now. When I changed the waterpump when I first got the car, I had trouble with it also. Couldn't get dialed in correctly then either, it has run a little rough since then. But it is complete sh!t right now. Followed the Haynes manual step by step to get it timed right and it's a no-go.
The belt had been changed by the previous owner so there are pre-existing marks on the gears and crankshaft pulley. I went by those before and again today and it's running like sh!t.
I tried starting over from scratch and getting cylinder one to top dead center and the mark on the crankshaft to match the raised lip on the block, wouldn't start, it turned over, but wouldn't start.
And now on top of that, I have a CEL that came on after I got it back together and took it for a spin. Gonna take it to AutoZone in the morning to get the codes.
Any ideas guys? Any advice? Is there any way to dial in the timing?
Thanks in advance.
Beaz
'97 Contour, with another problem.
