#535708 01/31/03 12:42 AM
When Frost ...Or dew On the rear window I will push my defraust ....the light Indicating that the defrauster is on does not come on But I do Hear the Relay Switch In the fuse panel Clicking Over ..What would cause this? and how would i fix this ?
18' Motegi MR3 Gunmetal racing wheels Toyo Proxes FZ4 225/35/18 Optix underbody Neons Audio:DHD 1000 Watt(lows) American Pro 400 (Mids) 4-5' Rockford Fosgates Carion CD Deck Pushin The Tweets . Kicker X3i Crossover DHD Power Cap
H
H
Quickest check is to remove relay from fuse panel and temporarily substitute with another relay from the panel that has the same color and plug arrangement. Possible relay contact has corroded due to lack of use in your climate.
ill try that ...Ill let yall Know ..Most likely the relay is burnt ...well C !
I have similar problem, only about half the rear defroster works, only half the fros will dissapear, no matter how long the defrost is on the rest will not melt, any input?
2000 Silver Frost SVT resonator removed 20% tints obx short shifter eibachs & konis ...more to come...
Just an idea,
Have you tried the plugs on the back window? i think there is one on each side. If only one, try cleaning then reconnect.
Sounds like the conductive paint is scratched through somewhere between the part that works and the part that doesn't, probably on the wide strip at the side, or all the lines that don't work are scratched.
If you look closely in the right light you should see it.
Go to the store and ask for some defroster repair paint.
Clean the area and mask off the edges. Then use the conductive paint. Let it dry thoroughly before using.
figured out the problem ..Somehow ...The relay burnt up the same day i replaced the Fuse that blew ...So this whole time i was thinking i replaced everything ...well i went back and my relay was gone ..Well I fixed it ..
Peace
well i got a prob w/ mine too. when i got it from th dealer, the defroster wasnt working right. id press the button and nothing happend. i took out button and noticed that the wires were plugged into the spare thing to the right of the defroster button. so i put em back into the button. but now when i hit the buton, the little light indicating that its on doesnt come on.... i dont know what u guys mean by a relay switch behind the fueses and stuff...i dunno..
'99 ČoňtôúŔ SE Kenwood KDC-MPV7019 AudioBahn AW1206T Flame Q Sub AudioBahn 1300HCQ Amp Blue LED Switches and HVAC
Check the fuse Box under the sterring wheel ...mine was blown . I had a 15 watt instead of a 30
