#533480 01/28/03 11:02 PM
H
H
Hi, I've been having a problem on my 99 SVT. It seems to be shifting pretty stiffly, but not all of the time. 1st to 2nd seems to be the biggest problem as when I'm accelerating fastly and throw it from 1st to 2nd it doesn't want to get into the groove. So I end up missing the gear and the stick pops into neutral. Every once in a while it leads to a slight grind that I can feel through the stick when it does make it into gear, this also happens when shifting and driving slowly every once in a while. Any help would be greatly appreciated. All I got from the archives was the clutch bleeding and cocktail (which I haven't done) but I was wondering if there was anything else. Thanks in advance.
Hussein
99 Black CSVT:- For sale, check classifieds and search for "Tempe". Mods: Borla Catback, K&N Filter, SS Brake Lines, rear cross drilled rotors Audio: Blaupunkt Alaska, Eclipse 5X7"s
#533481 01/28/03 11:16 PM
mine does that too, but only when its cold, it seems.
Diesel owns you
#533482 01/28/03 11:19 PM
Try the cocktail first then post, i'm sure it will solve your problem.
98 3.0 svt: Sold
#533483 01/28/03 11:23 PM
Z
Z
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
#533484 01/29/03 01:25 AM
I think there is a TSB recall for this..... I had mine done 2 weeks after i bought the car... they had to change the tranny fluid. But, I had the clutch replaced by for under warrrenty "dont ask" and they must have put the crap back in...
#533485 01/29/03 07:44 PM
Look (search) into 2nd gear synchros.. Mine did that (look for a post of mine, on the old boards, about my transmission)..
My particular problem ended up being the shift-linkage had snapped.. (but the synchros were bad, too..)
The slower I went, the easier to change gears.. and it was like no matter HOW much I was SURE it was in gear.. it would grind when I let out the clutch...
Ray
