W
W
I own a 1996 Contour and suddenly the check engine light went on. They used the computer to scan and I replaced the oxygen sensor, and the maf sensor. The computer didn´t find any more problems but the light is still on. They already done a extensive search and they told me that the car doesn´t have any problems. What could be the cause?
Arturo Castañeda Orduña
You need to reset the pcm. It has a "Keep alive Memory". Pull the #4 and #11 fuse from the underhood fusebox (next to the battery)wait five minutes and put them back in. This should solve the problem. If not, take it back to the guy with the scanner and have him erase it for you.-Kyle
Kyle Pickett (Austin,TX)
98 SVT (silver)
#860 of 6535
Eibachs/Konis
18" TSW SGVs-225/40/18 Sumitomos
KKM intake/BAT inlet pipe
KKM pedals
Sho Shop pulleys
B&M shifter/ATR aluminum knob
mesh grilles
Autometer shift lite
SCA sidemarkers
Hose Techniques SuperBlue hose kit
Home-made rear STB
