#530604 01/24/03 02:16 AM
just today, after i filled the car up as soon as i came to my fist full stop the car just freaked out and started to shake vilantly unless i gave it a considerable amount of gas, other wise it stalls, i was told that it could be the ias idle control sensor, what do you all think.
#530605 01/24/03 05:40 AM
IAC - idle air control (valve)
Lots of posts on that issue.
#530606 01/24/03 06:00 PM
The IAC valve or a vacuum leak in one of the hoses leading into the accordian tube are typical causes of idle problems. The IAC is about $70 so it's worth checking around a bit before replacing it.
#530607 01/24/03 06:37 PM
I had the same problem, and did research on the board. The IAC was the culprit - I did buy a new one from Ford, its on the shelf. I unplugged the IAC and cleaned the contacts, put some dielectric grease on the contacts, re-plugeed it, and NO more problem (for now)...
98 Black SVT
#530608 01/26/03 09:36 PM
Next day the same problem ONLY after car fully warmed up - replaced the IAC - still same problem. Car will bounce idle and stay at rpm that you were at when shifting (does not drop). Car runs fine until at 180 degrees... Any ideas?
THX!
98 Black SVT
