Posts: 331 |
Searched quickly but didn't come up with what I was looking for.
I am looking to sell my E1 front calipers to a fellow CEG'er, but he has a pre-98 and I'm not sure that they will fit. I seem to remember someone saying they will but I'd like to know for sure before I do sell them.
TIA,
Posts: 9,602 |
They will fit.
However they most likely require use of, at least, the E1 brackets as well.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 10,015 |
All calipers are the same. no matter what kind of contour. It's the brackets that change the pads.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 7,012 |
PM bmx contour he has them on his pre 98. peace.
Oo (xxx)oO
o xxxxxxxx o
Posts: 331 |
Thanks for the quick replies, very much appreciated!
Posts: 1,210 |
Originally posted by Stazi the Aussie: All calipers are the same. no matter what kind of contour. It's the brackets that change the pads.
The E0 calipers are different. I have them
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
Webmaster
Webmaster
Posts: 1,359 |
Yep, E0 calipers are quite different than the rest.
They will fit on pre-98's no problem if the brackets are used as well.
Also, 15" wheels are required, minimum. The spare will no longer work.
-Lance
Lance Kinley
CEG Webmaster
95 SE, "Cassandra"
10 years!
Posts: 339 |
You can just swap the E0 caliper on to the stock 260mm rotors without any bracket required. Not realy an upgrade IMHO except for a slightly larger size brake pad, but it should work. No clearance issues with the stock wheels w/this setup. Teamed with the SVT bracket and the larger rotors on the other hand would be a nice step up performance and then require the larger spare and 15" wheels.
Posts: 4,693 |
The E0 calipers will not work with the smaller rotors. The brake pads hit the hubs.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 339 |
Well there you go. Thanks Jim.
