#53216 02/10/02 12:43 AM
KJ Offline OP
Anyone know how to get it off. ASAP Please as it's getting annoying and cold.
Married the gal of my dreams 04.27.02 smile
2K SVT Black/Midnight Blue
#294 of 2150
DOB 10.29.99
kbucy@fbr.com
ktigerj on aim
A *few* Mods
Best Time 14.942 at 93.98mph
Car is now for sale - 14000
Which pully? The one on the end of the WP is a press fit, and doesn't come off.
'96 Mystique V6, ATX
KJ Offline OP
It's the pulley that's attached to the CAM on the LH.
#294 of 2150
DOB 10.29.99
kbucy@fbr.com
ktigerj on aim
A *few* Mods
For what it is worth...
"13. Using Crankshaft Damper Replacer T74P-6316-B and Water Pump Pulley Remover/Replacer with shaft protector and screws T94P-6312-AH or equivalent, remove water pump drive pulley from LH intake camshaft (6250).
the picture is vauge. is there a groove around the hub that is pressed onto the shaft? If so you need the special pulley remover/ install set that uses a split grooved washer. About $25 from harbour freight. $50 us made. These pull only on the hub and not anywhere on the pulley rim area.
Bill D.
to see what I am talkng about
HF part Number is 40749
at
http://www.harborfreight.com/cpi/ctaf/headsearch.taf?function=Search
Forgot to add...once you have the pulley pressed back on and the engine completley timed. go aherad and paint the pulley with a small mark to locate time without having to get down and check the crankshaft marks. This will save time if you ever have to reset engine to tdc before opening it up. just bump the starter until the painted mark is close. then final position with a wrench.
Bill D.
KJ Offline OP
The guy that is helping me supposedly has this at his house (1hr drive).
Thank you very much for the help.
#294 of 2150
DOB 10.29.99
kbucy@fbr.com
ktigerj on aim
A *few* Mods
