#527461 01/20/03 08:34 AM
N
N
What is the best off set to use with 19x8" wheels i am planning on using 225-35-19inch tires. I have ground control/koni struts installed. Thanks in advance for your help.
#527462 01/20/03 10:21 AM
I
I
40mm offset is what you should always use
#527463 01/20/03 10:59 PM
is that ATLEAST or what? because the 18" ADR reactions i just got from the GB is 42+ offset
95'Contour GL 2.5L (JUNKED!) ~~~ [Current Car] 1995 Ford Mustang 5speed [Upcoming Car] 2002 Trans Am WS6 (Black on Black)
#527464 01/20/03 11:07 PM
I am using a 42mm offset and rub like a mofo on 19x7.5 and 225/35 tires.
I didn't rub at all with a 47mm offset on my 19x8 Axis Se7ens with 215/35 tires.
My suspension is dropped 3" with Ground Control and Koni.
Bernie
#527465 01/20/03 11:16 PM
i dont believe i'll rub with 18x7.5 with 42 mm offset, even with the roush springs (i hope)
#527466 01/21/03 12:29 PM
N
N
Bernie how does your car ride with the new light weight 19" wheels?
#527467 01/21/03 08:22 PM
I
I
i thought a different offset would screw up your speedo and all that crap
#527468 01/21/03 08:44 PM
Pretty fackin' bouncy.
Nah, really I can't even tell the difference that much.
I feel it pulls a bit quicker now with the 15lbs wheels than it did with the, 27lbs Axis I had.
If you are looking for a nice ride, don't have 19s with a 3" drop on linear springs. I kind of enjoy it.
Bernie
#527469 01/21/03 10:10 PM
N
N
I wonder if the leda coilover kit that pascal had will feel less bouncy with 19's and give you that nice 3" drop
#527470 01/21/03 10:42 PM
Don't think so.
Bernie
Moderated by  1314_dup1
