#53188 02/09/02 12:41 AM
N
NODS Offline OP
N
My airbag light started blinking in a series of two blinks, a pause, then five more. Does this signify something. After car was shut off and restarted after fifteen minutes- no more blinking.
95 Contour SE-4 banger
NODS
95 Contour GL
"THE DAILY COMMUTER"
Aiwa mp3-plus a sub or two
#53189 02/09/02 01:13 AM
I believe that there is a recall for that. Have someone run your vin in Oasis. They will double check and see if you are eligable.
-Colter
My Car
#53190 02/09/02 09:57 AM
DUCK!!!
laugh
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
#53191 02/10/02 02:35 PM
There is no 2-5 code.
An Airbag 5-2 code is:
Backup power supply - voltage boost fault
Pinpoint Test P: LFC/DTC 52 - Backup Power Supply - Voltage Boost Fault
Normal Operation
A backup power supply is contained within the air bag diagnostic monitor that consists of four capacitors and a voltage boost circuit. The voltage boost circuit charges the capacitors to 16 - 19 volts when the ignition switch is turned to ON. The backup power supply is connected through a diode to the air bag diagnostic monitor pin C20a - 15, circuit 29 - MA15 (OG). The resistance of circuit 29 - MA15 (OG) should have infinite (open) resistance to ground. The air bag diagnostic monitor measures the voltage on the backup power supply capacitors. If the voltage on the capacitors does not reach a minimum of 16 volts after approximately 45 seconds, the air bag diagnostic monitor will flash diagnostic trouble code (DTC) 52 to indicate low voltage in the backup power supply voltage boost circuit.
Possible Causes
Low backup power supply voltage can be caused by:
1. Resistance on circuit 29 - MA15 (OG) to ground. Resistance to ground on 29 - MA15 (OG) or circuit 7 - MA20 (YE/BK) will cause the backup power supply capacitors to discharge and the boost circuit will not be able to boost the voltage.
2. Boost circuit failure within the air bag diagnostic monitor. If the voltage boost circuit in the air bag diagnostic monitor is faulty it will not be able to raise the backup power supply voltage on the capacitor.
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
