Right now I have 4 Firestone Firehawk P205/60R15 90H
Sometimes when there are a lot of load in the back and I go over bumps it scratches violently against the fender. I hear it is from the back so what tire should I get? I know it has to be thinner.
Question is what because it is really hazardous to drive like this on the road. The rims are 15" I think .. American Racing brand. They do look extra wide.
Thanks again for such -=)
96 Contour GL ATX
I
I
well WHEN I get money I'm getting some 205/50/16s and that should work just fine
having a lower profile tire will leave you with a big fender gap
but honestly I have no clue why your rear would sag so much cuz even 60s aren't that thick
I see that 50's are thinner but what does the last number mean??
Thanks
96 Contour GL ATX
It is likely they your wheels are the incorect offset.
don't drink and drive.
What does incorrect offset mean?
96 Contour GL ATX
I
I
the 15?? thats the size of your rim
from what i understand
205 would be how wide the wheel is, 50 would be the thickness of the wheel or sidewall, and 16 is the size of the rim
if the offset on your rims are not 40mm offset then it will throw off your speedo and miles and all that
check for broken rear coil springs,from what i hear its a common problem,i dont think a 205-60-15 should rub, i may be wrong though
EO 98 CSVT, black, gunmetal exel 18s, H&R springs ,custom grilles, 35% tint,Hightower headlights,resonator removed,Magnaflow installed,FMS 9mm wires,K&N,Redline MTL 2000 Impala silver 2 inch drop 17 inch Exels
I had rubbing where the fender meets the rear bumper - there's a "lip" that's about 2 1/2~3 inches long that was cutting into my tires over bumps and big dips, and heavy loads.
This is what I did:
- jack up car
- remove wheel
- remove fender liner
- detach bumper
- use Dremel to cut off "lip"
- clean
- touch up paint
No more rubbing. You can hammer the lip back, but I cut the fenders, just to be sure.
I also had some rubbing from the fender lip, so I also trimmed off the entire fender lip with a dremel using the same process above.
Good luck.
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
hmm sorry for being so questioning and stuff but my rims are 16" so I wonder why my current P205/60R/15 90H work?
Isn't 15 for 15" wheels? I am asking this because I want to buy P205/50/16 tomorrow.
Thanks once again
96 Contour GL ATX
I
I
are you sure they're 16"??
Im no expert on tires either but thats weird cuz I thought u need 16" tires with 16" rims
Moderated by  1314_dup1
