Ok, I am going to go with true duals. I want to know if my design would be good or if I should try to copy some elses.
Here's what I was thinking:
Cut the stock y pipe and make two pipes out of it. Then bolt this high flow cat:
Dual IN/Dual OUT Cat Then finish the job with dual mandrel bent piping to the mufflers in basicly the same position as the stock ones.
One question though; will I want resonators?
Will replacing the stock mufflers be a good idea and what mufflers should I replace them with?
Also I was going to get the mandrel bends from jcwhitney. Anyone found a better place?
