Posts: 4 |
I have a 97 contour sport V6, it needs to pass smog. But i have a big problem that most of you contour owners have. CEL on !!!! I already spend 700 bucks to change all 4 O2 sensor, but the CEL still on. I heard it was the cat. I am lost, don't know what to do, can some of you guys out there help ~
Posts: 2,408 |
Welcome to CEG!
Calm down!
It's better to find out what the problem is and not throw money at it.
Need to know the CEL code. And maybe you can explain why you just replaced all of the O2's. Either your rich (thats not it huh?) or someone/someshop said that would fix it. If the cel was just for a bad cat, then you might have one (lucky you, it's covered under the 8 yr/80k mi)warranty - it's not over 80k is it?).
The CEL can come on for a lot of reasons. If you just bought it there may be some routine maintenence to take care of too.
Come back with the CEL codes (not someones interpretation) and we will get you some help. Take it to get the codes read for free (Autozone, or call around) and post them on this thread. If there are any driveability issues, include that too.
Can you or someone you trust do some of the work? Saves money.
See ya.
Posts: 1,325 |
Lots of us CEG'rs have OBD-II tools and would scan your codes for you. Also, if you aren't close to anyone most autozones (maybe not in CA anymore) will tell you your codes for free without selling you lots of parts in the process.
If it is your cats and you are under 80k miles the Federal 8/80 emission warranty will cover you so not to worry about that either.
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 4 |
THANX TO YOU GUYS, but mine V6 is 110,000 miles on it.  I went to Autozone before to do the free diagnostic and found out i need to change the O2 sensor, buit now, they don't do that anymore.
Posts: 1,325 |
Well, if you have new O2's and are still getting a bad Cat CEL, chances are you might have a bad cat (how's that for logic!).
Since the O2's only check pre-cats, it possible your main cat is fine and you would still pass the sniff test if you could make your light go out. That being said, you can buy (or make) MIL eliminators that trick the PCM into thinking the CATs are functiong fine - no more CEL. Then as long as you main cat is reasonably healthy and your engine is otherwise in decent shape you should pass no problem.
If you do need to fix the precats on your money it is quite expensive, both parts and labor!
where in CA are you, I know I have a code reader here in SD, and pretty sure there are guys up in central and Northern CA with them too. Post down in CA forum to check if anyonee is close to you.
97 Contour SE MTX
