Bill D Offline OP
My 95 smoked the fan on sunday, I took it in Monday and they replaced the fan motor, blades, wiring harness and a new fuse. Took a day and a half to get parts and install it all for free under the recall. I thought I would be getting the double fan. They now have a seperate motor+blade set so no new shroud with double fans.
If I had known I would have seen about paying extra to get the double fan set. Kinda scary that Fords makes a replacement wirng harnes that is in regional stock for this car.
Bill D
isn't the single fan is larger, if so then it probablt has equal capacity to the two smaller fans.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
The single fan is fine..its a two speed,on 'low' the feed runs throu a resistor mounted in the fan shroud, on high it does not....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
