If your ABS light comes on, you'll definitely know what it is: #3 Yellow 60 amp fuse, that SHOULD be an 80 amp fuse. I had that problem about two weeks after I bought my car; the heater blower stopped and the ABS light kicked on. Apparently, the dealer's fix was to replace the 60 amp fuse with a black 80 amp fuse (which, if you're controlling the ABS AND the blower, don't you think you'd need a higher amp fuse???). Anyways, just something to watch out for. :p
