Posts: 1,592 |
I didn't, I've had a miss for the last two weeks. Tonight I finally found out why.
Master P
Master P
Posts: 5,455 |
Posts: 3,419 |
Wow, I wonder what causes that? Get any liquids in the coil pack? I assume you used dielectric grease on there when installing those wires.
Master P
Master P
Posts: 5,455 |
Originally posted by PA 3L SVT: I assume you used dielectric grease on there when installing those wires. Tim's an electrician by trade. Of course he didn't!
Posts: 3,165 |
That's not good. Any ideas of the cause?
Posts: 4,042 |
I knew I got Magnecores for a reason, and threw away my Taylors.
John
Posts: 7,329 |
Originally posted by perry: Shoulda got Magnecor! I love mine...
Administrator
Administrator
Posts: 5,037 |
Well, congrats man! Glad I could help you TWO WEEKS AGO!!! :p P- that's funny about him being an electrician
Posts: 3,237 |
That's corrosion. You must've got the terminal wet. Always use dielectric grease on electrical connectors to prevent chit like that from happening.
Posts: 1,592 |
Originally posted by L8 Apexing Aussie: That's corrosion. You must've got the terminal wet. Always use dielectric grease on electrical connectors to prevent chit like that from happening. Correction, Ford dealer must have gotten it wet. They've had my car apart so many times in the last year, I believe it was them. They suck! ok, I feel better now.
