N
N
I need to check and maybe replace the Mega Fuse on my 1996 V6 Contour. Can some tell me exactly where that fuse is located and what it made look like? Appreciate any help, thanks!
1
Gosh man, I only know that the fise on the Zetec is below the throttle body behind the intake, It may be located in the same place on the v6?
H
H
Clamped to wiring harness on rear of engine, pass side
N
N
Someone from the past (1yr + ago) mentioned the V6 placement was different. Supposed to be under coil/ignition pack on his '95. Now, is the coil/ignition pack the spark plug wiring? I'm not too familiar with the terms...
N
N
horseydug - Is the wiring harness easily accessible without taking apart other things to get to it? Thanks man.
H
H
Yes, but easily accessible and Contour engine compartment should never be used in the same sentence.
N
N
I hear ya!
take off the coilpack and look down. there is a wire from the alt. that goes into one end and then there is a wafer fuse just like the car stereo fuses, and then another lead out the other side.....PITA to get to...
Ben
95 SE ATX Electric red mucho mods 2005 Scion xB Black Sand Pearl tinted windows red leather steering wheel US Army Mechanic
N
N
Hmm, now I'm confused to as where the Mega fuse is located on a V6 - either under the coil pack or clamped on to a wiring harness in the back on the passenger side? Or are these the same areas being described and I don't realize it?
I apologize for my lack of knowledge. I'd like to know exactly where before I go messing around in this bitterly COLD temperature here in NYC.
