#52959 02/06/02 04:38 AM
How did you folks get it to open up after taking out all the bolt. please help me A.S.A.P. its in the garage ass we speak
Infinity 6 1/2 in. speakers in all doors
2 10in. Kenwood Tornado Subs
Logic Soundlabs 840 watt amp
my car would be sweet if the cops didnt take all my money
JVT Offline
Use a screwdriver to pry the housing apart.
JB
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
I had to hit mine hard with a hammer to get it to break free.
MarkO
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course."
#9 - Hitting .400 for ever
"Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez
"The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
JVT Offline
Originally posted by MarkO:
I had to hit mine [b]hard with a hammer to get it to break free.
MarkO[/b]
Do that if the above doesn't work. wink
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
try using a heat gun. The heat will eventually soften the selant enought where it will break free and allot easy removal.
a screwdriver will work, but be careful not to gouge up the housing or it may not seal properly.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
I had to hit mine [b]hard with a hammer to get it to break free.[/b]
Well it is a Ford afterall... eek laugh
2000 SVT #674 - Check it out!
There is a notch between the two parts of the WP. on the top of the WP, that is large enough for a large screwdriver blade to fit in. Just put a screwdriver in and twist. Unless you hammer it in you won't come near the sealing faces.
Don't hit the thing with a hammer! When all the bolts are removed the whole WP assy is loose, so hitting the front of it won't break the seal from the main housing.
'96 Mystique V6, ATX
Yes, the whole assy is loose. Yes, hitting it hard will break the seal. I know it does, I had to do it. I was more concerned with damaging the mating surface of the rear assy by prying with a screwdriver so hitting the front assy (which is going in the bin anyway) is the lesser of two evils. 2000 miles on the new pump w/out probs so.....
MarkO
hammer did the trick thanks
