Page 3 of 3 1 2 3
#520342 01/16/03 02:57 AM
H
Hajax Offline OP
H
Glad to hear you got it fixed....Sounds like it was going the same think mine was....
Hank '98 Contour SE
#520343 01/16/03 03:00 AM
H
Hajax Offline OP
H
Check to see if the cable is engaging the lock mechanism. You should be able to look down at the lock assembly with the trunk open...push the remote and see what's going on. If you can't tell, you'll have to take the lock and solenoid out to see what the problem is. My guess is that one of those cables is out of alignment.
Hank '98 Contour SE
#520344 01/16/03 05:01 PM
im having the same problem with my 98 SVT. I can see two like cylinder shaped things, one white and the other red, are these the solenoids that you all are talking about? i still havent figured out how to go about fixing it.
98 SVT #1652 of 6535 My SVT "If everything seems to be going well, you obviously don't know what the hell is going on."
#520345 01/16/03 05:30 PM
H
H
Here is a picture of the solenoid (I hope this is the solenoid) once I disassembled it. SOLONOID You can see the gears...and the motor sitting inside. Note: the connection is not complete unless the sliding mechanism is in. I tried to just connect the piece with the motor in it and push the trunk button...didn't work. Then I noticed that the sliding mechanism (with the teeth on the side) has to be in to connect the current...then it worked fine. I cleaned it up a bit and put it back together. Hope this helps. By the way..this is located to the left of the lock mechanism (if you're looking toward the front of the car). It's hidden under the steel and is attached by two screws. Enjoy.
HE-MAN
#520346 01/16/03 05:50 PM
Thanks for the info!
#520347 01/16/03 09:11 PM
H
H
Originally posted by AlbanianSteve:
....I can see two like cylinder shaped things, one white and the other red, are these the solenoids that you all are talking about?..
Close, but no cigar. What you're referring to are the termination sleeves for the key-lock and manual remote cables on the pass side of latch. Go to driver's side of latch in the body cavity, and that is where the solenoid resides.
HEMAN: Thanks for posting pic.
#520348 01/17/03 05:15 PM
hmm. i'll check that out, thanks for the help!
Page 3 of 3 1 2 3
