Posts: 9 |
Help guys I spun a bearing on my V6 They are quoting me $2200 for machining the crankshaft; and I personally don't think it is worth it. Could I get a new performance crankshaft? What about a 3.0 conversion? Could I run a higher viscosity oil in the mean time? Oh yeah I only got 54k. Help!!!
Posts: 3,567 |
When a bearing spins there is usually damage done to the crankshaft. Sometimes there is no damage, but generally the damage is measured in thousands of an inch, and is usually undetectable by visual inspection, but by checking with a micrometer you will find the problem.
The main reason for the shop quoting for reworking the crankshaft is that the rework also consists of a magnetic particle inspection that will detect microscopic stress cracks. Not only that but the rework also consists of refinishing the bearing surfaces to ensure a true and round surface to allow for optimum bearing break-in conditions and service life.
I would rule out a performance crankshaft since repairing the stock one will cost signifigantly less
a 3.0 conversion is definately a possibility, if you are willing to spend the money.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 3,567 |
If a braring is spun a higher viscosity oil will not solve any problems.
Posts: 1,445 |
i think the 3.0 is cheaper
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 5,805 |
NO.....Dont run it,dont use it....a spun bearing will damage the rod end/ main bearing caps...keep using it and you could toast the block and/or more con rods....Heavy oil flows slower...old wives tail that it helps....the price is fair for tearing down the motor etc....you could end up with a whole new motor if you continue to run plus a load of metal in the oil that will wreck the rest of the motor....more $$$$ on rebuild....
Posts: 2,794 |
If crank is in hand (you pull engine and bring them the crank) how much does it run to do it? How much of that $2200 is his labor?
Just call me Judge. People suck. Life begins at 170mph...until that point it is just boring.....
Posts: 5,805 |
Common'Brian, you know dealer 'engine' builders, what would you do????
Posts: 3,562 |
Originally posted by Terry Haines: Common'Brian, you know dealer 'engine' builders, what would you do???? GASP! You know they aren't "builders" Terry! They are merely parts exchangers... :p Heheheh. Freeagent, if you need something to drive in the mean time, buy a POS run-about for a short time, it's much cheaper than ruining more expensive parts in your Duratec engine... With the money you can save doing the work yourself, you can easily buy and then sell a couple hundred dollar car and end up with a 3 liter Contour in the process!
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 198 |
That's what machine shops are for.... It has been awhile since I rebuilt a motor but I always took the block and crank to be hot tanked, magnafluxed and mic'd. Saved me big bucks.....
Posts: 1,611 |
Might see what they are charging you in labor to pull motor and such, it might be cheaper to buy a good short block from an SVT (like the one I'm selling) and use it to gain a better engine. This is most definitely the time to think about an upgrade. Most any work on the bottom end of the motor is the most expensive for this car.
Rick
The first Blown 3 Liter! "Drive it till the wheels fall off" -my personal motto!!!! 98.5 T-Red SVT #6180 Many Mods Buckshot77@aol.com Owner of 00 #1611 Silver Totalled on 10/7/01 SVT Parts for Sale
