Hi All!
I'm quite new to this board so, if my questions have been answered in the past, forgive me. I have read some posts, but there are so many that it's probably quicker to ask.
Some History.
I bought my 98.5 Contour about 7 months ago (94000km) and have put 27000km on it since. It came off a lease.
- I haven't had any major trouble other than brakes and the Air bag light flashing.
- I have replaced the back brakes.
- The front driver-side rotor is now warped. (I have been told that they were new when I bought it and that it would be safe to drive if I couldn't afford to replace it, although it would be quite annoying). That was some time ago now. It hasn't gotten any worse.
- The Airbag light was flashing 4 times, then a pause, then twice, then a pause , then the cycle started again. I took it to the Ford dealer and they checked the recalls. All 6 recalls on my car had not been performed. Ford did them over 2 Saturdays.
My new problem is a "rubbing" sound at certain speeds. Between 60kph(35mph) and up to 100kph(60mph) I get a rubbing from the front passenger-side(I think). It sounds just like road noise only I can feel it through the gas pedal. As I accelerate up past 100kph it goes away.
The noise is most noticeable at around 90kph when I bank the car left (to change lanes, or on a slight left turn in the road). If I turn the steering wheel slightly to the left (about 1/4inch) the noise is present. If I turn the wheel to the right (about 1/4inch) the noise goes away temporarily.
I had it looked at (and explained this to the tech running the shop) and the result was they changed the Back Left Bearing????? But, this did not solve the problem! The shop wanted to look at it again (and charge me again for this "inspection") but I have refused. This was not at the Ford dealer, but a Canadian Tire shop close to where I work.
I would like to know if someone can tell me what the problem might be before I spend more $$$$.
I know I am going to have to replace the front Brakes and am trying to save the money, but this other problem seems more important right now.
I love the car. It handles like a dream. I commute about 120km total each day to work and back (all hi-way driving). My busy schedule has prevented me from taking it to the Ford Dealer. But, I think I might have to.
Anyone know the answer?
