Posts: 144 |
How the heck do I get this factory piece out?
asap Thanks
Brenden
'99 SVT Silver Frost Love to read up on any mods. Any recommendations, feel free to let me know. AIM: PlayT88
Posts: 246 |
on my car i had to use a removal tool and stick it in the 2 vertical holes on each side
_Eric_ 95' Performance White Contour Gl Zetec ATX -A beautiful girlfriend next to me...what other mod is important?
Posts: 107 |
Yeah you should have two U shaped pieces of metal that slip into the holes on either side of the radio. You just push them in and yank it out. It just takes some work to get it out. good luck
98 MTX V6 SE Sport KKM Mangnaflow muffler and res.
Posts: 587 |
In an effor to help elaborate on the previous posts... You need what they call a "Single Din" radio removal tool. Two seperate pieces of metal, each shaped into a "U" shape. The sides of your factory radio have these two holes in which you press the "u" into, and pull out.
You can pick up this tool at (most conveniently) Wal-Mart.. less than $5..
Hope this helps.. Ray
Posts: 221 |
i was able to borrow the Ford keys from a SAAB dealership (they have the same thing), but I still couldn't get it out. I ended up destroying the old factory CD player to get it out. I ripped all the pieces off that I could and then used a pair of pliers to finish it off. Felt gooooooood Hope you have more luck.
Darren '98 Mystique LS -Duratec, MTX Nakamichi CD-40z, Knauberized, K&N drop-in...what else could you want?
Posts: 345 |
Get a wire coat hanger.
Cut off two 6 inch long pieces.
Bend the pieces in the shape of a U.
Locate the holes at the corners of the head unit.
Insert one 'tool'about 1/2 inch into the upper and lower left side holes, the other in the upper and lower right side holes.
While pulling outward (toward the doors) on the 'tools' to release the latches, work the head unit out of the dash.
It fits snugly so it make take some convincing, but it will come out without damaging the dash or the head unit.
AL
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 1,445 |
Originally posted by Darren G: i was able to borrow the Ford keys from a SAAB dealership (they have the same thing), but I still couldn't get it out. I ended up destroying the old factory CD player to get it out. I ripped all the pieces off that I could and then used a pair of pliers to finish it off. Felt gooooooood
Hope you have more luck.did u let out a primal scream afterwards???
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 144 |
Thanks guys! You've all been a great help and I appreciate your time.
Brenden
