#518808 01/08/03 10:31 PM
jaedee Offline OP
I have an airbag code of 45-any ideas? Second, my car idles at around 600rpm and seems like it wants to stall. I have replaced the IAC and changed the UIM/LIM gaskets about two months ago-any ideas on this one?
#518809 01/08/03 10:35 PM
H
H
For the idling problem, it could be a problem with the fuel system. Try replacing the fuel filter underneath the car and see if that helps. Other fuel related issues could be the pump or the screen/filter for the pump (not the fuel filter underneath the car).
#518810 01/08/03 10:44 PM
My guess is a vacuum leak associated with either the UIM/LIM gasket replacement or an external vacuum line...
Regards, Art
2004 Velocity Red RX-8 *Racing Beat Intake and Exhaust *Grand Touring Package *Red/Black Leather *Fender Strakes *Rotary Accents *Xenon HID's *Bose
#518811 01/09/03 01:10 PM
