Only found vague references to this problem in the archives....
My rear, driver-side, running light is out. It's not the bulb, I swapped bulbs with known good passenger-side bulb and it still didn't light.
Used a Volt Meter on the wiring harness in the trunk and it appears there is no voltage even getting to the bulb fixture.
There's only one fuse for the running lights, right?????
Now it appears my front driver-side light is out as well (somehow I don't think it's the bulb :-( )
Anyone familiar with this problem????
Thanks a ton.
