I guess this never got posted but the fix was expensive.
$54 tow . $71 min. 1 hour diagnosis. The service supervisor (the pimp for the technician) said they 'thought they found the problem -- but that it would probably take till the next day and that the 'shuttle' stopped shuttling after 430pm.. ( I guess we got the car there about 230 or 3pm not sure) ..so i took the shuttle home .. I then got a messages saying they found the problem and come pick up the car (that day about 5or 530 pm) .[ I think they close at 6pm ].
When I told them what was wrong I said the computer was dead or not powered something to that effect. ]
It was found that the bus wire to the computer had been corroded away. He showed me the corrosion. (I had spent a week trying to find out what was wrong with the car the whole 1st,damn cold week of January.)
If the ass would have just told me bus to the computer corroded -- I would have been able to replace some damn wire myself .. apparently the tech spent 2 additional hours doing this .. but the pimp said 'it took a lot of time to find the problem' .
so 1hr diag + 2 hr labor is just $71 *3 = 213. + 8% NYS tax + $54 tow it ended up being just over $300..
Conclusion:
if no computer codes , pull the battery and pull the stupid black bubble wrap enclosure FROM UNDER THE BATTERY out and
check the wires under there for corrosion (probably from battery acid spillover) ..
The pimp indicated this was normal and that there was nothing that could have been done to prevent it .
...and a sucker is born everyday ..
