Posts: 50 |
My CEL came on about two days ago I took it to autozone and the P1383 code (variable cam time overretarded bank#1) showed up. what does this mean? i tried to start my car again and drive home but it wouldn't start back up. I have about 75,000 miles
Realness
1999 Ford Contour LX
Posts: 122 |
I assume your 'Tour has the Zetec (4-cylinder) engine. If so, Technical Service Bulletin (TSB) 99-13-8 may apply to you. Strictly speaking, if you tell your Service Department you have P1383, they should find this TSB on their own, but it would probably be wise to "help" them find it.
Garrick
2006 Mazda6 Grand Sport wagon, silver, MTX
I'll never forget you: Silver E0, #3895 of 6535, built 10/2/97
Posts: 50 |
I am sorry, what do you mean by Technical Service Bulletin (TSB) 99-13-8? where would I find that?
Realness
Posts: 5 |
95 GL v6 ATX sunroof, cc, power seats, yeah its got everything.
Posts: 1,412 |
I really dislike your name.....(walks away mumbling...)
Posts: 2,408 |
P1383 means mechanical timing is off : Timing belt jumped
Posts: 50 |
so does this mean i have to replace the timing belt?
Realness
Posts: 122 |
Originally posted by Rogerm60: P1383 means mechanical timing is off : Timing belt jumped
That's just one possibility. Strictly speaking, it means the cam timing falls outside of a pre-set range or remains retarded even when retarded camshaft timing isn't called for.
Possible causes: Cam timing improperly set, continuous oil flow to the VCT (variable cam timing) piston chamber, VCT solenoid stuck open, or camshaft advance mechanism is binding.
The TSB I mentioned addresses the VCT control system being hung up on a machining burr or the oil feed to the VCT system being plugged with debris. It's certainly worth considering, in light of Ford's publishing a specific procedure just for that trouble code.
Garrick
Posts: 2,408 |
At 75k I would change the timing belt anyway. Just check the static timing before you take the old one off to see if that is the problem. If not, yes VCT would be checked next.
