If you remove the panel located below the steering wheel and look up, towards the rear of the light switch, you will see a white relay that will possibly be taped up to the wiring harness.
You can pull the relay down and hold it in your hand and turn the fogs on and off. If the relay works, you will feel and hear it click. If not, then the relay is bad.
Hope this helps you out!
