Hey folks...Just a heads up on a fix to my 1995 Contour GL w/MTX with about 104K. Since the onset of cold weather, I have had a problem when making sweeping right handers with a grinding noise from the drivers side frontend. When the temperature was above 50 degrees, the noise went away. Thoughts of CV Joint, or wheel bearing were running through my head. The problem ended up being the transmission mount being worn out. This was allowing the motor/transmission to drop about an inch or so, which was in turn causing some rubbing on the frame.
