Originally posted by contour96: My cel keeps going on and off...could this be a short somewhere?
No, this is probably not a short, but most likely means that something is starting to go bad.
Originally posted by contour96: I need to go to autozone and get it checked when the damn thing is on to see what the code is. Thanks in advance!
You can go to Autozone anytime (not just when the CEL light is on). Even thought the CEL is not currently on, if the CEL lit up, then it stored a CEL code in the car's computer. You can go get that read anytime.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
