#513741 01/04/03 07:27 AM
On the PCV system air is taken from the intake boot (after the MAF) and run thru small tubes to both valve covers, thru the motor and back thru the PCV valve into the intake tract once again, but this time all full of nasty stuff. This is how I understand the system to work.
My question regards the air that is entering the valve covers from the intake boot. Is this air forced out the intake boot or is it pulled from the intake boot by vacuum from the crankcase? It's a fine distinction, but I'm just curious as to which way it is.
It seems to me that w/all the air the TB is pulling in (creating vacuum) that air would have to be sucked from the intake tract in order to make the system work.
Am I correct here? Does this make any sence? TIA
#513742 01/05/03 03:59 AM
F
F
Hmm...Good question!
Anyone know?
Thx
#513743 01/05/03 04:47 AM
The PCV valve regulates the amount of air drawn through the crankcase. The air is the filtered air after the MAF (so it is metered). From the boot (Which is "high pressure" before the Throttle body)through the crankcase, through the PCV valve and then to intake manifold ("Low Pressure" or "high vacuum", if you prefer). Except for some a small amount of blowby (exhaust gases getting past the compression rings on the piston) and a little bit of oil carried over, the air really isn't that nasty. The oil is the real problem and can be helped with a better oil separator (Cover somewhere in this site). Before PCV, not only did the exhaust gases escape untreated, the environmnet in the crankcase was miserable. Hot, lot's of sulfur, and moisture could not escape easily. Besides the air quality issue, PCV is actually good for the engine (as long as you don't carry over the oil, anyway)
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
#513744 01/05/03 07:41 AM
The above explanation was good, but let me try another aproach.
The PCV valve is a one way valve. It allows flow in one direction only (there is an exception, but for the sake of this discussion, we won't go there yet). The flow is into the intake manifold, usually at a point that provides even distribution into all cylinders. The flow is from the crankcase. The purpose of the PCV is to ventilate the crankcase. Before PCV systems, this ventalation was from a road draft tube, which was ineffective below speeds of about 25 mph. The road draft tube also allowed fumes into the atmosphere and the PCV captures them. To pull the fumes off the crankcase, fresh air must enter from another hose. This hose is connected to the intake prior to the throttle body. Air circulates through this tube, into the crankcase, into the tube with the PCV valve, and then into the intake manifold so that the fumes are directed into the combustion chamber to be burned. Where did these fumes come from? They are unburned air / fuel mixture that got past the rings (called blow-by). Even an perfectly operating engine has some blow-by. So the PCV system is keeping the fuel from the blow-by from contaminating the engine oil and sends it back to the combustion chamber.
All of this is well and good as long as there is suffecient vacuum to scavenge the fumes. During low vacuum events, the blow-by will re-enter the intake from both hoses, on both sides of the throttle body, but still not allowing them loose into the atmosphere.
By the way, the PCV system was the first smog device. It came into wide use in 1961 (if you really wanted to know). The very first PCV systems did not have the return hose to the air filter area. The closed system as we have it today came a little later. Converting to a closed system by adding a hose became a required modification on title transfer on cars that were built with an open system.
Probably more than you wanted to know.
