#52438 01/29/02 02:45 AM
F
fjones Offline OP
F
My daughter has a '97 Mystique with a 2.0 Zetec engine and auto. The car just turned 50,000 miles and runs great. The problem we are having is the car idles too low (500 rpm) when in drive and the air conditioning is on. The Haynes Repair Manual refers to an "Idle Increase Solenoid Valve". Does anyone know if the 2.0 Zetec has this valve or what increases the rpms when the air conditioning is on. I know the engine rpms use to increase when turning the air conditioning on when the car was new. Thanks.
#52439 01/29/02 03:12 PM
I have a 96 with the exact same problem (65,000 miles).
Independent mechanic tried to fix with no luck. Dealer says that it cannot be adjusted (computer chip controleld) but diagnostics will determine which component is not working properly and replace it. Cost to diagnose, $110. I told them to shove it! My daughter can live with low idle. Everything seems to be running fine otherwise.
#52440 01/31/02 05:55 PM
As a note, I have a 96 with bout 60k miles.. same problem. I had someone diagnose it but couldn't find anything (not a dealer). I don't know if he checked the computer controls.
#52441 02/01/02 08:50 AM
guys, this is normal idle speed when in gear. put it in neutral, and it should go back to around 1000 rpms. i also have a '97 mystique zetec automatic. it has 99000 miles on it, and still runs like a top. still has the stock timing belt and plugs and wires. dont mess with it if it ain't broke (although these will get replaced at 100K- the belt wont though). everyone with a zetec will tell you that theirs idles lower when you put it into gear. live with it. put it into neutral if you want smooth.
i will always have a comeback! :o)
#52442 02/01/02 03:42 PM
Well, sort of disagree. I will live with it but.
Every car I now own has a normal idle speed of about 750 RPMs with no A/C and engine hot. The Ford dealer also states that normal should be 750 RPMs with no A/C on and engine hot.
I can live with the 600 though as long as it continues to run fine.
#52443 02/01/02 04:06 PM
Thought I'd chime in to let everyone know that my little zetec is running at 680 @ idle while in drive and right at 800 in park/neutral when I hooked it up to the scanner. Oh, and for being a 4 banger, mines pretty smooth and quite while in gear.
James
jpett@flash.net
StolonTour97
Riding on 17" ADR Trauma's wrapped in Falken ZE512 215/40/ZR17
#52444 02/04/02 05:52 AM
Red Offline
I have 2 96 zetecs and they both idle very low
one guy told me that the injectors were shot.
that or the wiring harness.
Black 96 gl
mostly unchanged
except for the urge to have it crushed
#52445 02/04/02 05:37 PM
I have a 97 Mystique Zetec with 62,500 miles on it and it has always idled low when in drive. It sometimes even goes as low as 450 rpms while sitting in traffic, but never stalls. It feels like it wants to though. I figure when it starts stalling, I'll get it fixed.
#52446 02/05/02 12:40 AM
Mine normally idles at about 950 RPM's when the clutch is in and when out of gear, but I noticed yesterday when I left work I got to a stop sign and when I pushed the clutch in and held it there for a few mins while at the light the idle dropped to 500 and felt like it was going to stall, 1st time that has happened...now it does it every now and then... car has 56500 miles on it and the engine only has 21000 miles on it... Normal, or should I be worried? :rolleyes:
~*TJ*~ 97 GL Sport Zetec
~*RIP*~Connie~*1/21/02*
~*Mods*~ E0 SVT Rims~205/55R16 Goodyear American Eagles~
~*Mods to come*~ H&R springs~Konis~Coilovers~17x7 Millie Miglia Avia~215/45R17 S-03's~SVT body kit~98+ OE Spoiler~CAI~Brullen Cat-Back~Turbo (or 2):)~
More to come
#52447 02/05/02 09:28 AM
My 2000 Focus idles around 650-750 rpms. Only 12000 miles on her.
Ryan French
98 Mystique Duratec Sport(KKM, Custom Exhaust, debadged/dedinged, Tinted, A4 sidemarkers(clear), Bodycolor grill...Suspension is next.)
00 ZX3 Zetec Limited Edition(nothing)
