Posts: 119 |
Hello, I'm looking to upgrade the exhaust on my mystique, but I don't have a whole lot of money. I'm probably going to stay with the stock system and just get a performance muffler of some sort. What would be my best bet for a muffler? Again, I'm not looking to get a dual system, just the muffler. I'm probably looking mostly for sound improvent, as I won't kid myself with the performance gains staying with the otherwise stock exhaust. Thank you.
2000 T-Red Mystique LS
-STOCK-
My Car
Posts: 1,379 |
You can probably pick up a used SVT exhaust for under $100. Some guys even give them away. Stainless piping and mandrel bends, cant beat that!
~~~~~~Mike~~~~~~
Black 2006 VW Rabbit
Silver 2000 Contour SVT - SOLD
~~~~ The Car~~~~~
Redneck Troll
Redneck Troll
Posts: 2,621 |
You can get great gains by modifying the stock single exhaust and spend very little money by doing so.
Replace the resonator with a Dynomax perforated core racing muffler, or straight pipe if you want it really loud, then swap out the rear muffler for a 40 series Deltaflow Flowmaster muffler. Replace the stub of pipe from the collector pipe to the cat as it knecks down to 2" on the non-SVTs, which should be 2.25" instead. You can also modify your stock Y-pipe with a better merge collector and find a few HP.
http://www.bnmotorsports.com
Posts: 119 |
Originally posted by bnoon: You can get great gains by modifying the stock single exhaust and spend very little money by doing so.
Cool, thanks for the suggestions. Just a couple questions, where can I buy the dynomax and flowmaster mufflers, and how much (approx.) do they each cost? I went to the Dynomax website but wasn't sure which type of muffler you were talking about. Thanks!
-STOCK-
My Car
Redneck Troll
Redneck Troll
Posts: 2,621 |
I'd do summitracing.com, part number WLK-24211 for the resonator replacement (perforated core glasspack, 35" length to reduce drone as much as possible). Then use FLO-942443, or something similar depending on where you want your inlet/outlet for the tips.
Posts: 119 |
Originally posted by bnoon: I'd do summitracing.com, part number WLK-24211 for the resonator replacement (perforated core glasspack, 35" length to reduce drone as much as possible). Then use FLO-942443, or something similar depending on where you want your inlet/outlet for the tips.
Cool, thank you very much!
-STOCK-
My Car
