#52427 01/29/02 02:15 AM
Scott Offline OP
What should I do to keep my battery posts from coroding.
Thanks,
Scott
#52428 01/29/02 03:22 AM
clean them up real good then rub some grease on them.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
#52429 01/29/02 04:25 AM
Popular among Truck Mechanics: Permatex HiTack ..(check Spelling)..it's a gasket adhesive but great for sealing the terminals up to prevent corrosion. Bright Red Translucent color, spray on like paint.
The other is Lubriplate white grease. Almost as good. Collects dust but works well.
Clean terminals, coat with either and no more corrosion.
"My Name is Richard. I am a Contouraholic."
1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades;
Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod;
PIAA 9006 Super White Headlamps
AIWA CDC-MP3 HU; WeatherTech Mats
Viper 600ESP w/Remote entry
#52430 01/29/02 04:33 AM
2
2
Pick up a battery brush at Autozone to clean the terminals. I bought one for $2, and I like it. It's silver with 2 brushes- one for the terminal top, and one for the inside of the terminal. Also use a dremel or some sand paper to clean the smaller rings while you're at it. Then use the stuff recommended above.
2000 SE Sport V6
Deep Navy CC Metallic
My 2G Sport
#52431 01/29/02 04:52 AM
6
6
to neutralize the acid and help clean them, use a mix of baking soda and water.
I have a dream, and that is a 69 Boss 302 with Jules Asner in it.
Current - 2002 Chevy Silverado
Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
#52432 01/29/02 05:33 AM
Scott Offline OP
Thanks for the quick response and good advice.
Scott
#52433 01/29/02 06:42 AM
Originally posted by Richard C.:
Permatex HiTack
battery terminal protector
White lithium grease that comes in a aerosol can
LPS-3
Dinotrol AV-30
Permatex HiTack
Motor oil applied with a brush
vasoline (don't get any ideas)
di-electric grease (DC 4 compund)
spray paint
heck, even crisco would work
any oil or grease like substance that will prevent the bare metal of the terminal from being exposed to the vented gasses from the battery
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
#52434 01/29/02 09:22 PM
F
F
I use Krylon,s Crystal Clear Acrylic. (1301 part no.) Spray/coat liberally all parts, after they are clean, grease free, neutralized. Couple coats or three. Should be good for all year or even longer. I've used this method for over 15 years now.
I use this on all my antenna, grounds automotive or around the house. I usually do this when I first get a new car to all connections, mainly because of all the salt on our roads in the winter. It seals out moisture and doesn't attract dirt. Any electrical connection benefits from no corrision for many reasons.
proper prep -- this is ideal.
Paul Echelberger
N8BUU
Paul
N8BUU
#52435 01/29/02 09:43 PM
I heard that a can of coke works too, but who wants a sticky battery :rolleyes:
James
jpett@flash.net
StolonTour97
Riding on 17" ADR Trauma's wrapped in Falken ZE512 215/40/ZR17
#52436 01/30/02 04:04 AM
That's very true. However I recommend diet coke because it does not have any sugar in it...
2000 SVT #674 - Check it out!
