#52386 01/27/02 11:24 PM
Hey. Just noticed that when my turn signal is on the headlight on the same side dims. (on turn signal flash, headlight dims. between each turn signal flash the headlight returns) Any ideas?
#52387 01/27/02 11:35 PM
Bad ground on the turnlight bulb holder....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#52388 01/30/02 10:29 PM
Thanks, but how do I go ahead and check/fix this problem?
#52389 01/30/02 11:04 PM
Chack all the ground wires behind the headlamps,unscrew any grounds,clean the terminals & bodywork where they screw in and re connect......
V6 MTX
#52390 02/02/02 09:54 PM
Thanks!
