Originally posted by SVTMini-Flea:
1. They haven't removed the y-pipe but simply cut it before it dumped into a single pipe.
2. Then, due to the fuel cell, they use flex pipes to take the exhaust down the driver side around the fuel cell and to the back of the car.
3. The cat placement is really up to you.
1. Cutting the stock Y-pipe (or aftermarket mandrel Y) and making 2 seperate pipes is in effect removing the Y-pipe. 2 seperate pipes = no Y-pipe
2. Definitely DO NOT use POS flex piping nor crush bends. IMO if you are going to do a project like this as least do it worth a damn. Just think of the velocity & energy loss caused by 6-7 crush bends in EACH PIPE!
Also DO NOT use shared mufflers. (I.E. Dual in dual out) You will effectively be negating the entire dual setup letting the exhaust gasses mingle. Maybe even making it worse then a tuned Y-pipe would???
Also Dan Beggs (99 Cougar) has been running straight back duals for over a year with no problems.
3. For reference - remember there will be double of everything. If you want cats then you will need 2 of them. 2 resonators, 2 mufflers, 2 flex joints, etc since their are 2 seperate pipes.
