#506887 12/24/02 04:32 PM
how hard is it to change the alternator on the 2.5 i think i migth have to be changing my alternator soon. cause the battery ligth comes on above 5,000 rpm and the battery doesnt seem to be dying out. it shows 14 volts from idle to 5,000 rpm and 13 volts above 5,000 rpm. is there any special procedure for changing the alternator that i should knwo about, and how much does one usualy go for?
98 contour s.e. sport mtx http://www.cardomain.com/memberpage/503352 all mods shown on page
#506888 12/24/02 07:04 PM
H
H
Ive never done one myself but she certainly is buried fairly deep - good luck
Tea 82 242Ti Proud former owner - Samantha '98 SVT #2253 Reborn Aug 21 2002 Cobra Paradise
#506889 12/25/02 02:57 AM
I had the same problem. First it happened at 4500 rpm then 4000 and lower. Last friday was very lucky to get home (last 10km drived just on battery).
To take it out I was busy all Saturday, mostly scratching my head and thinking how to get to the bolts without removing driveaxle and Y-pipe.
It could be done with a lot of different extensions, good 1/2 socket and tonns of swearing!
In my case the brushes was so weared I never ever seen enything more messy in generators in my life (well, I'm still maybe too young). Friend of mine tried to take the alternator apart to clean the messy and bumpy rings on the lath and broke it (it is not desined for unassemblying at all!). So I got another one, but was forced to keep the voltage regulator of the old one, because those 3-pin terminals could be different (were in my case)!!
Tomorrow I will try to install it back and maybe will take some pictures.
Good luck.
Contour GL 1995 V6 2.5L, 5 spd. 170000km
#506890 12/25/02 03:48 AM
U
U
Please do so! I know that several of us 2.5L owners would love to have this on hand!
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
#506891 12/25/02 04:27 AM
Cool Toe Chris
Cool Toe Chris
Yes please do! I need to change out my generator soonly. Any pix/tips (other than rhe FAQ and the service manual) is appreciated!
Chris NJ 98.5 SVT Silver Frost
#506892 12/25/02 06:07 AM
I don't know if it will help or not but I took mine out from the wheelwell. All I had to do was disconnect the tie rod and remove the screws for the small plasitc pieces that are part of the fender lining and it came out relativly easy. The hardest part was getting the top bolt undone. Ford put this one in VERY TIGHT. Other than that it was easy. You just need to have a little patients and you will end up having to twist and turn it to get it out of that hole in the fender. If you have any questions you can PM me.
98 SVT 18" Enkei RS6's, NITTO 555 Extremes Intrax lowering springs K&N filter Sho-Shop Y pipe (without cats) Stock "gutted" manifolds Carbon Fiber Cowl hood Carbon fiber sail panels
#506893 12/25/02 05:10 PM
Cool Toe Chris
Cool Toe Chris
Thanks! I'll PM you before I start the R&R. The only thing I'm really worries about is removing the tie rod properly, since I have never done that.
#506894 12/25/02 07:40 PM
9
I made a pretty good how-to of the 2.5 alternator replacement on the old boards. Done mine twice now, if you need more help let me know.... -Nick
http://www.contour.org/archive/showflat.php?Cat=&Board=UBB3&Number=140365&Forum=All_Forums&Words=alternator&Match=Entire%20Phrase&Searchpage=0&Limit=200&Old=allposts&Main=140363&Search=true#Post140365
EDIT: as far as the tie rod removal, All I did was hit it a bit with a hammer, those removal tools that pry it out, they like to dammage the rubber.
"Moore has also accused the American people of being the stupidest, most naive people on the face of the Earth. And after last weekend, he's got the box office numbers to prove it!"
#506895 12/26/02 12:17 AM
Cool Toe Chris
Cool Toe Chris
Thanks for the link to the write up! I'll be changing mine out soonly and let you all know how it goes.
#506896 12/26/02 02:14 AM
Just take the nut off the tie rod end and then screw it back on until the nut is flush with the end of the stud then hit the nut straight up. Make sure that you hit it straight though.
