Posts: 1,049 |
im new to the contour scene and i just baught a 98 contour se 5 speed. i mainly wanna add more power without ruining the smooth quiet ride. whats with the throttle body swaps ive been reading about. wich ones can be used and from what cars and what works best?
Posts: 2,387 |
Not a great idea to start modding with. Concentrate on the basics first...y pipe, exhaust, open element air filter.
98 3.0 svt: Sold
Posts: 1,834 |
While I agree with Konto, to answer your question....from what i remember and have heard, the best 2 options are SVT tb and the 4.6 stang tb, though I believe that one requires some modification to work, and possibly some help in the air/fuel regulation dept. Hopefully someone with more expertise than me will chime in to comfirm or deny this. Basic concensus seems to be that our cars don't benefit from bigger tb's as readily as a lot of other cars seem to. Hope that helps.
Shawn Clone
Jezabel- 1999 SE Sport V6 MTX- Severly wounded, comatose
Silver frost/Black Exterior-Midnight Blue Interior
The Firecracker- 1995 Mystique LS V6 MTX stock and backfiring like a rifle shot
I have 3 loves, my God, Brittany, and my Car.
Posts: 5,810 |
Modifications: yes, but not too bad on the 65mm
Air fuel adjust: Not that i've seen. warmonger
See My Mods
Redneck Troll
Redneck Troll
Posts: 2,621 |
Originally posted by {Kontofosho}: Not a great idea to start modding with. Concentrate on the basics first...y pipe, exhaust, open element air filter.
Actually, the SVT TB is a great first mod to a stock Contour SE. Throttle response was greatly improved, as was just about everything on the top end too. Of course I optimized mine before it went on, but it was my first "mod wave" along with the KKM. Since I took the KKM off a couple of times try to cure a MIL I was having at the time, I got plenty of time driving around with only the TB in place on an otherwise stock SE. It was my favorite of all of the mods I've done, even since then, because it simply transformed the car...
http://www.bnmotorsports.com
Posts: 1,516 |
I'll tell you what, a 65mm TB is good, but not the best right off the bat. The SVT one is the best option. I have had a 65mm for about 1 1/2 months, and it has way too much throttle responce (compaired to the stock one) and takes a little getting use to. I had to buy and extra throttle spring to help me out. It gives pretty good increase in top end, but not an extreme amount, but the low end is increased pretty well. Oh yea BTW, get ready to drop 2mpg in gas milage...I'm running 17.5
Mazda 6S, V6, Speed Yellow
5 Speed, Sport package
Bose audio
Painted 'stash and HIDs!
w/Injen 1/4 14.750 @ 94.94
Former car:
99 Contour SE Sport Black MTX V6
SVT plastic...
1/4 - 15.012 @ 90.58
Posts: 3,627 |
so how much we talking on the 65mm TB $$$ wise that is?
Trollin the boards as of 9/23
Originally posted by GS474: stock hp is never enough
Posts: 9,602 |
Originally posted by mmarfan: I'll tell you what, a 65mm TB is good, but not the best right off the bat. The SVT one is the best option. I have had a 65mm for about 1 1/2 months, and it has way too much throttle responce (compaired to the stock one) and takes a little getting use to. I had to buy and extra throttle spring to help me out. It gives pretty good increase in top end, but not an extreme amount, but the low end is increased pretty well.
Placebo effect!!! I know. I thought the same thing until I actually tested it. The 65mm has shown to lose power on even moderately modified SVT's. It will most definitely lose power and any non-SVT. Upgrading to an optimized 60mm TB is the best choice.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,627 |
I would assume it is kinda like flooding the engine, is that correct?
Posts: 63 |
Not really flooding... But you do start to lose intake air velocity and that can cause some minor problems. The ECU should know that more air is comming in and adjust the mixture accordingly... unless, of course, you have exeeded the parameters of the ECU.....
IMHO when it comes to the intake side, SVT got it right. The SVT TB (IIRC from a 3.0L Duratec) is about as big as you want to go unless you have some really heavy mods going on.
