#505972 12/23/02 02:51 AM
anyone do a rack job on one of our cars, my rack is pushin out like 3 quarts of fluid a day and i wanted to know if its easy or if its a b***h like the ford probe?? any tips or tactics to use?? well thanks
98se, cheap exhaust-hopefully soon the brullen, hella rs bodykit and eibach's and koni's soon, 17" konig persuits, falken 512 215/45/17, lots more to come, anyone with a pre 98 trunk pm me if you can get rid of it. aim name is konig17se98
#505973 12/24/02 03:52 AM
anyone?? anyone??
#505974 12/24/02 05:15 AM
It's not easy. It looks worse than it is, but it still is not easy.
#505975 12/24/02 01:22 PM
U
U
If I knew I had to do one, I would not like it. If you have to do it at home, at least invest or have all 4 wheels off the ground with jack stands.
One note of caution that I know sounds really dumb, but a lot of people forget to do before R&Ring a rack... Center the steering wheel, remove the key (do not allow the steering wheel to lock itself, this mean you have to move the steering wheel. You know when you remove the key and turn the wheel a little in one direction and the wheel locks. Don't allow this to happen!!) and find something to lock the steering wheel in the centered position, from inside the car.
Why?
If you don't have that steering wheel centered when you get that new rack in there, the alignment shop will send you back home and tell you to center it. This will mean that you will have to pull the rack again!!! Reason being, if it is not centered when in connect the spline of the steering column to the rack, you will never center the wheel through an alignment. If it is not too far off center, they "might" set your toe back into spec, but the wheel will possibly still be crooked as hell.
I did this one time... One Time!! Just a small note of caution!
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
