Posts: 31 |
my resonator is taken off, and i have to go for an emission testing next week, will that effect the test ? i still have that middle muffler, and i will out it up if it will but i don't want to - car sounds so sweeeet.
95 contour Lx V6 Cold air intake SVT exaust upper and lower main. from SVT
2 12' punch 2 800.2 punch amplifiers Pioneer DEH-P730 cd player
Posts: 171 |
There is a fluid you add to your gass and it makes you pass any emissin test guarenteed. You can get it at any auto parts store it comes in a smaller bottle about the size of a drygas bottle that should hook you up pretty good!
Later Jerry
97 Contour Sport V6. T-Red, KKM tru rev induction, Ford racing wires, Cooper Cobras GTH, A pillar gauge pods with ford racing gauges, Clifford Matrix alarm, painted red calipers, full bra, premium audio installed,LED's, Ford Racing seat belt pads. It's my baby!!! I love to pull up to a honda or a VW and blow their "fast and furious" doors off. Imports can suck my american exhaust!!!
Posts: 1,861 |
Originally posted by Import*Killer: There is a fluid you add to your gass and it makes you pass any emissin test guarenteed. You can get it at any auto parts store it comes in a smaller bottle about the size of a drygas bottle that should hook you up pretty good!
Later Jerry Pure "Snake Oil". It doesn't really do much. Forgetaboutit.
Jim Johnson 98 SVT
Posts: 1,861 |
[QUOTE]Originally posted by yogibear: [QB]my resonator is taken off, and i have to go for an emission testing next week, will that effect the test ? i still have that middle muffler, and i will out it up if it will but i don't want to - car sounds so sweeeet.
The removal of the resonator should have no effect on a smog test.
Jim Johnson 98 SVT
Posts: 171 |
That stuff does work really well on emission test its not just snake oil! Trust me.
Jerry
Posts: 31 |
thanks, i will not put it back on then
Posts: 753 |
One bottle probably won't do alot for you - but adding a "bunch" of alchohol will reduce your total HC count. Your car will try to richen up some due to the higher O2 content of alchohol, but a big chunk of your combustion will be from the OH so your HC's will still come down. Your car may run like poopoo like that, but your HC's should be way down anyway. Also, isopropyl is kinder to the rubber lines and seals than methyl.
Anyway, the resonator will have no effect so don't sweat it.
Posts: 1,537 |
I've swapped out my single pipe for an SVT Cat-Back, without the resonator(Front Muffler). I passed my Emissions last week with no sweat.
If you ever need anything to put in your tank, this is the only stuff I use.
GUMOUT REGANE
This stuff works so well you will actually feel the performance gain. Put one bottle in a full tank of gas and run it down as much as you can. It lasts for up to 6000 miles. It cleans the carbon from valves and the cylinder heads. Also cleans your fuel injectors, and carburetor(for older cars). I haven't used anything else in any of the cars I had. And the second fillup, after you appy the REGANE is when you will feel the difference.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
