Well, I thought is was the weirdest thing when I started my car one night and it had a whistle at idle. It also does it when I just let off the gas. At full or part throttle it seems to go away. It was cold so I thought it was a random thing. Its been doing it every day now. I have played with the throttle (under hood) while listening for the source and is sounds like its the throttle body. Could my throttle plate have some kinda little hole or something. I have done a forum search and found a few others with a similar issue but no posts had a follow up fix.
I was thinking to re-torque the throttle body bolts since I did recently install an svt upper.
Any input would be helpful
tx
98 Silver Frost Contour SE Sport ATX
BAT Handling Kit, SVT E1 Wheels, SVT TB, UIM, Airbox , SVT Exhaust, Rear Strut Brace, Pioneer Deck and 12 disc changer, Pioneer 6X8's
I know on some after market throttle bodies for the mustang they had a prob. with whistling, not sure about the tour i dont think it is going to harm anything its just damn annoying.
Mike | 98 Silver CSVT
the whistling sound is the sound made as the air squeezes past the throttle plate.
If you have an after market induction system like a KKM then it will be more noticable.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
What song is it whistling?
Could be a vacuum leak somewhere, like a vacuum hose, loose PCV valve, etc.
Dan B.
The whistling sound means that the car is working. wink
1999 Contour SE Sport MTX75 T-Red/Grey
Audio: Pioneer DEH-7400MP (MP3 CD), Pioneer TS-A6857 front & rear, PPI PCX-250, Infinity Perfect 10.1
Other: cup holders, cargo net, Blizzaks, Potenza RE950s
well, I wish it was due to some aftermarket induction system but its just the stock svt setup on my car. I have had the same set up for a while. The whistling is new. Its not the moose...and its not the cool kkm sound..its a annoying high pitch whistling sound. I'm checking into it now since I have the afternoon off. If I figure anything out, I'll post it so others wont have to deal with it cause its freak'n annoying!
Kai Offline
I have it too. Actually got it after I replaced the cabin air filter. Don't know why that would be connected to engine revs though. confused
Kendall
'97 GL Zetec ATX
" Nippy "
Maybe the "Moose" is loose. It tends to come out in cold weather.
Jim Johnson
98 SVT
